Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-09-2005, 05:37 PM
XGamesJ6's Avatar
XGamesJ6 XGamesJ6 is offline
'93 Cutlass Supreme SL Vents???
I have a 1993 Oldsmobile Cutlass Supreme SL with a 3.1 V6 engine. and lately the vents dont seem to work..it blows fine but it only comes out of the front window defrost vent..and the floor vents..it wont change to anything else..only both of those. it wont switch to the regular vents...or just one of the two vents...anything i can do to check what it might be..or what can it be..my first guess is that a pencil or something got caught in the trap doors for the vent system..but my dad says its something with the vaccum hoses...what do you guys think..any help would rock! thnx
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
Old 09-10-2005, 07:04 PM
Rusty280Z Rusty280Z is offline
Send a message via Yahoo to Rusty280Z
They are actuated by vacumm. My 92 Cutless Supreme SL valves are located below the glove box compartment -- inside the dash. The glove box compartment in mine removes by just pulling on it. I have a bad valve also, cannot get airflow to the upper vents. I hope this helps you a little bit.
Old 09-10-2005, 09:58 PM
XGamesJ6's Avatar
Re: '93 Cutlass Supreme SL Vents???
i took a look at it..and it all sounds right...where is this valve or where do i look first. looks to me like theres a box where all the vaccum lines go to..but im not sure if thts anything or not
Old 09-10-2005, 10:47 PM
The valves are located next to the ducting with a vacumm line attached. The valves I have are circular and attach to a adjusting rod, that operates the air duct. Look around the ducting and if they are like mine, they will be near the ducting.
Old 10-30-2005, 07:12 PM
XGamesJ6's Avatar
i dont know what the problem is...the lines that go to each control arm thing have no suction...could it be that box where all the lines are routed to. or is there a bigger line somewhere else from the engine i should check out?
