Crank Position Sensor Symptoms
My 97 SSE has the symptoms consistent with CPS problems. Starts when the engine is cold but wont start when warmed up after sitting for about 5 minutes. Let it sit for half an hour and she cranks right up again.
My question is this. Is there any way to make it start when this happens other than waiting around for 1/2 an hour. I just cant resist the urge to keep twisting the key even though it is useless. I am overseas so I will have difficulty replacing any major parts for american made cars that require special tools. So I need tempory "Make it go" solution for the next 8 Month's. Any suggestios would be appreciated. |
Re: Crank Position Sensor Symptoms
Re: Re: Crank Position Sensor Symptoms
Thanks for the response. |
Re: Re: Re: Crank Position Sensor Symptoms
No luck with the spray bottle. The sensor is behind a shield. Guess I just have to make one way trips...
Cooling with water is working.
You need a squeeze bottle to get the water to the right spot. Squirt a stream between the pullies where the wiring harness to the sensor is. Takes a few bottles of water to cool sufficiently. Thanks for the Make it go Solution! |
