Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 09-09-2005, 04:03 PM
greatone7 greatone7 is offline
2002 sentra 1.8 drive belts
can anyone give me some ideas how to get the drive belts of a 1.8 engine? There's no auto-tensioners....do i need to remove a pulley?
Thanks!
Old 09-09-2005, 07:57 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: 2002 sentra 1.8 drive belts
if theres no auto tensioner then theres a manual tensioner. 2 bolts, 1 goes thru a slide bracked, the other is at a 90 degree angle and is pretty long. loosen the bracket bolt a little then loosen the long bolt to adjust the tension
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 09-10-2005, 02:41 PM
thanks for the help...i see the manual tensioner and will give it a try.
Old 09-12-2005, 02:23 PM
ok, I tried loosening the manual tension, but no matter how much I loosen it, the belt doesn't loosen...none of the pulley budge. Do i need to attack it with a prybar or something to get it to loosen? (Thanks for any help anyone can provide)>
Old 09-13-2005, 04:42 AM
is the side bracket bolt also go thru the alternator or something? you need to loosen the bottom bolt of the alternator(or whatever accessory its attached to) in order for it to swing.
