Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 09-09-2005, 12:29 PM
Jmore Jmore is offline
Monte Carlo window motor
Is it difficult to replace driverside window motor.
Is it acessible once you got the door panels off?
Old 09-09-2005, 01:04 PM
montie0690 montie0690 is offline
If it is a 95 then I can help. The way I removed mine was I took the door pannel off (window up to reach motor) for the motor their are 3 rivets that you will have to remove and replace with something that is about 1/8 in depth to let the slides clear or new rivets would work to. Take a good look at the spring it gave me some $hit Other than that it wasent to bad. It was a wile ago so I dont rember move for move what i did but I do rember takeing a screwdriver and hammer to the rivits and grinding the head of the bolts on the pavement to make the slides move past the bolts and I renamed the spring #!^%&*!#@%*(& in case you need to call it by name when you are takeing it off. Good luck.
hit me back or check me out cardomain
Old 09-14-2005, 12:12 PM
mbrdmyr mbrdmyr is offline
Send a message via Yahoo to mbrdmyr
I have a 96 and my dad just replaced my motor for me too, I remember he screwed the gear to the plate thing to keep the tension for the spring, then removed the motor by removing the rivots and then puting the new one in and I was thinking that the new one came with screws to replace the rivots. Good luck!
