Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-09-2005, 11:29 AM
tr10av tr10av is offline
Send a message via MSN to tr10av
2 problems in new car
Well I just got my 96 ESi a week ago and I just started noticing 2 things.
First:
Whenever I apply my brakes I hear a noise coming from my front right tire I think. Not really sure how to describe it. It's kind of like a womp, womp, womp.
Second:
After I stop my car and turn it off I can hear a weird ticking noise coming from the front right of the engine compartment(as you're sitting in the car). It seems to be closer to the bottom than the top. This noise lasts for about 1-1 1/2 minutes after I turn off the car. I'm not sure if this noise is present when I drive or not.
Also, is there anyway to post a sound on the internet?
Thanks
'87 Chrysler NewYorker
2 12" Ascendant Audio Assasins in Sealed Box
Hifonics TXi 6406 Bridged to 2 Channels
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
Old 09-09-2005, 03:27 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
1) Try tightening up the lugs on the wheels, they could be loose.
2) I've never heard of anything that lasts 1-1.5 mins after a car is off. I know there is the sound of the ecu turning off when you turn the car off and maybe some bulbling of coolant but what you described Im at a loss.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 09-09-2005, 04:27 PM
macder macder is offline
Send a message via MSN to macder
Re: 2 problems in new car
1.Take of the wheel that you hear noise from and check the condition of your brake rotors and pads. After torque the wheels to ~90lbs/ft.
2. My best "Internet" guess on the sound you've described when the car is off: The high temperature from your exhaust is heating a heat shield (most likely your exhaust manifold heat shield) causing the metal to make a "crackling" noise. Think back to high school science and the theory of molecules.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 09-09-2005, 04:37 PM
Re: Re: 2 problems in new car
I'll do that tonight.
That sounds like a logical explanation.
Will this damage anything on my car because of the excess heat? This problem happens when driving short distances(4 miles). Should my exhaust be getting that hot that quickly?
VR3 CD/MP3 Player
COMING SOON:
Component Set
Amp for components
Old 09-09-2005, 06:18 PM
On your next day off, try to remove the exhaust manifold heat shield and check if the exhaust manifold has cracks in it (Have new bolts and a threader, these bolts are usually not easy to remove and they often snap). This would raise the temperature of the heat shield. The extra heat should'nt cause any problems as long as your engine cooling system is 100%. The extra heat going on the cylinder head (not really extra since it's coming from the exhaust valves) from the exhaust should be easily cooled down by the coolant flowing through the head. I drove around for 3 years w/ cracks in the exhaust manifold and never ran into any problems.
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
