Old 09-09-2005, 02:11 AM
doodooboi doodooboi is offline
Send a message via AIM to doodooboi
rebuild GS-T
I have a 95 gs-t and it has about 120k miles. i want to do an engine rebuild. what parts do you suggest that i put into my engine? my friend told me to put in low compression pistons. i am going to tear appart the head and block. i want to make it run really good. are there any parts that are a must?
Old 09-09-2005, 09:26 AM
SpyderGuy97's Avatar
SpyderGuy97 SpyderGuy97 is offline
Send a message via AIM to SpyderGuy97
Try slowboyracing for a stroker kit. That would be a nice upgrade.
Zack
Old 09-09-2005, 09:55 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: rebuild GS-T
How much are you looking to spend?
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 09-16-2005, 02:08 AM
less then 2000
Old 09-16-2005, 07:30 AM
-Josh-'s Avatar
Re: rebuild GS-T
You're not going to rebuild any engine for less than $2000, no way. Unless you're best buddies with someone at a machine shop.
AF User Guidelines
Old 09-16-2005, 09:07 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Re: rebuild GS-T
Yes you can. If you have the abillity to do the work yourslelf! Maching only costs around $400
DSM geek
Old 09-16-2005, 09:33 AM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
Re: rebuild GS-T
Bullsh*t... -Josh- you have got to be kidding... You can build a 2.4 slowboy stroker for less than 2 grand... I just rebuilt the motor in my Gs-t. Total cost for pistons,rings, all bearings and gaskets... under 500 (with a shaved head). Rebuild kits are 350.00 from slowboy. Compression test reads 165 across the board
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 09-16-2005, 01:38 PM
-Josh-'s Avatar
Re: rebuild GS-T
Meh, i've never seen it done, but if you guys have done it, i suppose it's possible.
Cost a friend and i about 2200 to rebuild his 3.8....different engine i know. That's good to know though for when i rebuild my engine...coming soon...probably next summer.
Edit: After some more research you guys are right, my bad. I dont take into account the availbility of aftermarket on these cars as compared to the GM 3.8. But now i'm all excited to rebuild mine...lol
AF User Guidelines
