Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-09-2005, 02:10 AM
intrcptrbird intrcptrbird is offline
Send a message via AIM to intrcptrbird
Exhaust leak
I've been getting this weird noise coming from the engine/tranmission area recently and the other weekend I had a chance to jack up the car and take a look at the area to see what was wrong (I was thinking like a cracked heatshield or something). When I got under there I didnt notice anything right away but after a while I saw that the top exhaust manifold bolt on the rear cylinder on the driver's side was snapped onn with a portion of it still left in the head. I've heard somewhere else that in order to get these manifolds off you need to pull the entire engine to do it. I was just wondering if that's true and/or if you guys had any suyggestions. Thanks in advance for the help.
Old 09-09-2005, 01:15 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Exhaust leak
You have to disconnect the steering shaft and move it out of the way. Also remove the bolt that holds the dipstick tube in place.
Old 09-09-2005, 07:07 PM
coondawg6 coondawg6 is offline
bird is right the most you might have to loosen the motor mount on that side to get clearance
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
