Old 09-09-2005, 12:30 AM
roonie roonie is offline
help with cruise control
my 1990 silverado cruise control has not worked from the day i bought the truck.I would like to fix it.any ideas as to where to start fixing.what is the most common part that quits with these cruise controls?thanks
Old 09-09-2005, 01:43 AM
2000CAYukon 2000CAYukon is offline
Re: help with cruise control
Stick or automatic?
Cruise should disable when the brake is pressed; perhaps, your switch is adjusted wrong and the cruise control thinks you have your foot on the brake pedal. This is the first thing you should check.
In the 90 FSM, there are 3 pages of diagnostics for checking each component of the cruise control. The fuse for the cruise control is shared with the seat belt buzzer so if you hear the buzzer, the fuse is good.
//2000CAYukon
