Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 09-08-2005, 09:57 PM
smelser4 smelser4 is offline
runs bad sometimes
one day tha truck will run like a new one next day it won't run 35 mph any idea whats wrong 1987 b 2000
Old 09-09-2005, 11:11 AM
Wollf's Avatar
Wollf Wollf is offline
Re: runs bad sometimes
need a bit more info , what happens when it acts up , where are you going , up hills , flats ? rainy sunny ? anything
I work as a partsman in the BC Area if you need help finding something you cant find pm me here and i will see what i can do. www.lordco.com
Better to sit in silence and be thought stupid , then to open your mouth and remove all doubt.
Old 09-09-2005, 11:51 PM
Re: Re: runs bad sometimes
really im not sure i just got the truck from a friend all i know is he said the motor in the truck has 88000 miles on it and he replaced the coil trying to fix the problem that didnt fix it so he sold it
i am a mechanic but i work on rolls royce and bentley's that is a whole different world some one told me it might be the carb
Old 09-10-2005, 12:56 AM
Wollf's Avatar
ok Mr Mechanic, you know as well as anyone then , you need info , and all engines run generally the same , what applies for one , works for another. Cant just say , my car wont start , how much to fix it.... everyone needs info.
Old 09-11-2005, 07:14 PM
Re: Re: Re: runs bad sometimes
ok wolf the truck has no power from idle to about 2500 rpms this accurs driving or not driving
Old 09-13-2005, 10:15 AM
Bach4660 Bach4660 is offline
like Wollf was saying they all run the same, do you have spark on all four plugs?, pull the gas line and crank the motor, do you have gas, I am not sure about the '88's but the second gen have a glass plate on the float, if yours does, does it keep a steady fuel supply?, compression check within service limits, any major differences between cylinders, liquids, colour of the engine oil, etc.
