Old 09-08-2005, 07:19 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Few problems with Y8 swap
Well got my Y8 swap in and ready to run, but have ran into a few problems.
A) Of course the A6 timing belt cover wouldn't fit so I have to get one to set the timing just right.
B) I bought a used DC header from a guy of the board awhile back. Well it came with a O2 sensor in it (I'm assuming from a Z6 or Y8 because it has 4 wires). Who ever put the O2 sensor in has obviously cross threaded it, it will only come about half way out. Is there any way to hook the O2 sensor in there up? (which wires would control it right)
C) The Mech said there isn't a plug for the radiator fan. (I thought it just used the A6 plugs? I know you have to extend the rad fan wires to fit to the thermo plug, but hes saying the plug its self is defferent.) There is also a plug on the pass side of the block towards the front that I can't find a plug for. What does it go to?
D) When you let it idle it smokes white out the exhaust, but when you drive it it quits. I figure this is probably do to the timing being off and no O2 sensor (since the check engine light is on as well).
I think that about covers it for now. Thanks in advance
Old 09-09-2005, 08:07 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Few problems with Y8 swap
A) Can't you just use a timing light to find the correct timing?
B) Even if you wire up the O2 sensor to the four wires you'll still have an exhaust leak. I'd invest in a new header (if the bung is on the runner tube close to the head like stock) or if it's like my dc header where the bung is down near the cat, maybe have an exhaust shop cut the collector pipes and weld on a new end piece with a freshly threaded bung... if you can find a place good enough to do such work.
C) What wiring harness are you using anyway? Are you OBD0, OBD1, or OBD2? The connectors for the fan really shouldn't make much difference as long as the wires are soldered or connected good.
D) Probably like you said.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 09-09-2005, 12:28 PM
I am staying OBDO for now. I am not talking about the plug that connects to the fan. I'm talking about the plug that goes into the motor to tell the fans when to turn on. ON the A6 the plug is on the back of the motor, while on the Y8 its on the side on ther thermostat. You have to lengthen the wires I know, but the guy is trying to tell me the plugs are different.
I am going to go get it today so I will see for sure what he is talking about.
Old 09-09-2005, 03:11 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if you dont have the plug that goes intot he thermostat sensor then just take your stock sensor off and put it on hte y8
Team Lonely Drivers
Old 09-09-2005, 11:36 PM
Well have found another problem. Is was smoking really bad and I thought it was because the O2 sensor wasn't hooked up. So I get my old Si manifold and put it on with the O2 sensor.
Well it still smokes like crazy. So I have come to the conclusion the head is either cracked or warped because there is coolant getting into one of the cylinders. A mech had originally put the head on awhile back, and I think he over torqed the head and warped it. So looks like it's time to get the head decked.
