Old 09-08-2005, 07:16 PM
DragonofBC DragonofBC is offline
Send a message via AIM to DragonofBC
1st paycheck = new parts?
I started my career 2 weeks ago and I'm waiting on my first paycheck next Thursday. I think I want to get something for the car but I need some advice. My mods are in my sig and I'm trying to figure out what to buy next. You'll notice that I'm running on the stock exhaust and I, unfortunately, have to keep it that way for a little while. I'm thinking something with the fuel system but I don't know what to get first.
First off, I logged a few pulls and I have my boost set to 11.5 psi right now. I'm getting smooth timing curves. I turned it up to 14 and it dipped around 5.7k so I turned it down to 11.5 and haven't played with it since making sure there was no knock. I guess my options are SAFCII, injectors (660s), or fuel pump. I only plan on getting one right now but the rest will eventually be purchased.
The reason I say 660s is because they will flow enough fuel to max out the 16g, which is the furthest I plan on taking this car. I'm not upgrading the turbo again. I guess a question I have is will a 190 be sufficient to handle maxing out the 16g or do I have to go 255 + AFPR?
So what should I get? Or should I consider a FMIC or something else I haven't thought of? I just don't know what will help me the most. Thanks for your input.
2003 Mustang GT Convertible - 5sp. - K&N drop in, MAC catback, Eibach Pro Kit springs, Strange s/s, GMS UCAs/LCAs, MGW shifter, Nitto 275s out back. Does it ever end...
Old 09-08-2005, 07:34 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: 1st paycheck = new parts?
If you get 660 inj. you will need an S-AFC.. they kinda go hand in hand unless you have DSMlink...
If maxing out the 16G is something planned... go with a 255walbro and fpr...an exhaust would be helpfull also... everything you have stated kinda needs everything together... more boost needs bigger exhaust to allow it to flow.. more boost needs more fuel...bigger pump...bigger injectors...bigger inj.. S-AFC/DSMlink...
It's kinda a viscous circle but....it's all good..
I was running about 14psi on stock inj/pump/turbo and it ran pretty damn good...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 09-08-2005, 07:37 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
make sure to rewire the FP, if u have a pocketlogger, u dont need dsmlink if u get safc, but basically ur gonna need FP, injectors, safc, and rewire
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 09-08-2005, 08:47 PM
I should have included it in my sig, but I did rewire the pump. I kind of got the impression that everything needed to go together, but I was hoping you guys would tell me differently . I get the impression that the 190 won't support a maxed out 16g then and thats kind of a bummer.
I'm guessing I should start with the SAFC or fuel pump stuff and leave the injectors for later. Will the fuel pump allow me to turn up the boost more than being able to tune my current pump? Maybe I should purchase and closet some stuff for a bit...
Old 09-08-2005, 08:53 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Re: 1st paycheck = new parts?
I bought a Walboro 255 HP and it wasn't that expensive. I think it may have been the same price as the 190. You just have to look a bit.
I think I paid like 90 bucks for it.
1991 GSX 2.3 Stroker
Old 09-08-2005, 09:00 PM
255 is the same price, but u need an afpr too, which you have to be very careful hooking up and doublecheck everything
95 Eclipse GS-T
Currently:
Soon lol
Old 09-08-2005, 09:03 PM
the afpr doubles the price the "pump upgrade" in my mind which is why I'm trying to figure out if I can just go 190. If I didn't have to get the afpr, it would be 255 fo sho.
Old 09-08-2005, 10:12 PM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
You don't need the afpr. Everyone thinks you do. I had this conversation in another recent post. I've had absolutely no problems with mine without a fpr, and I've never heard of anyone needing one. A lot of guys in my area have the 255, and no one uses an FPR. Yes, I will go with popular belief that it helps... but it's not essential. That's just my two cents, and I bet I'll get some criticism for it.
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 09-08-2005, 11:18 PM
Your mod list is very impressive but I don't see a mention of a logger or DSMLink. From what I understand, the afpr is used to turn the fuel flow down. Do you have any problems with the car at idle? What does your a/f gauge read when you are under full boost? It would be great knowledge that I wouldn't need a afpr but I've see 255+afpr said so many times that its hard to be convinced otherwise.
Old 09-08-2005, 11:26 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Shut the fuck up! 50+ GPH = overflow. End of story. Want to spread bad information? Log the Fuck off!
Walbro 190 rewired supports the following:
9.5:1 (stock) AFR @ BFP @ 15psi = 44lb/min airflow
10:1 AFR @ BFP @ 15psi = 46lb/min airflow
10.5:1 AFR @ BFP @ 15psi = 49lb/min airflow
11.1:1 (fastest flame speed) AFR @ BFP @ 15psi = 52lb/min airflow
12:1 (RBT)AFR @ BFP @ 15psi = 56lb/min airflow
12.5:1 (good target) AFR @ BFP @ 15psi = 58lb/min airflow
13:1 (LBT)AFR @ BFP @ 15psi = 60lb/min airflow
14.68:1 (Sticho)AFR @ BFP @ 15psi = 68lb/min airflow
The Evo 16g will flow a max of 44lb/min. 255lp or hp is not nessessary!
Expect your BFP to be around 50psi if you use a Walbro 255hp and no AFPR. Over runing your FPR like that would turn a set of 660cc's into 710cc's. Not only would you have a major problem trying to get 660's dialed in correctly with a SAFC2 but you would never be running a correct AFR. Tuning would be a nightmare!! Thats not worth it! Spend the $130 and get an Aermotive afpr. Turn down the pressure, add a -6an return line, and screw a gauge into the gauge port. End of story.
Oh yeah 660cc's & reired 190 is a great combo. 190 flows a little the 1-2% more then the 660's are capable of. good combo.
DSM geek
Old 09-09-2005, 12:09 AM
Black97GST Black97GST is offline
why do you have to keep the stock exaust??? emissions?
Old 09-09-2005, 01:24 AM
Whathits14 Whathits14 is offline
some damn good info from scottsee.
No way in hell you need 255lph pump.
190 flows enough for ~400hp which probably wont happen with the EVO III without some major work. 660s will be good for the EVO III. SAFC when you get you injectors for sure unless you go dsmlink. Looking at your mod list, I would also look into an intercooler upgrade, get it used to save some major bucks or if you are handy, fab one yourself for pocket change (compared to a kit). But before any of that, get some exhaust...if you keep a cat of put a new one in, you will have no problems with emissions. Go for a custom built one and weld on a muffler that does not sound like shit. I have a flowmasters 40 series and it sounds mean...sets off car alarms.
If you do decide to go with the 190, I have one lying around brand new, that I need to get rid of. Make me any resonable offer.
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 09-09-2005, 05:59 AM
Awesome info going on here. Thanks scottsee for the nice 190 writeup. Whathits: I sent you a pm.
The reason I'm staying with the stock exhaust for now is kind of a silly reason. My parents offered to pay my car insurance for me through December while I get settled with my new job as long as I don't change the exhaust on my car. It doesn't even make sense to me but as long as I'm getting my insurance paid for, I'm not going to mess with a good thing. Eventually, I'll change it, just not yet.
Old 09-09-2005, 08:16 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
I'm still on the stock exhaust for a different reason......I really hate the loudness. Scottse says it's because I'm a pussy
Anyway, 2 months ago on the stock exhaust I dynoed 242.5WHP. Since the addition of my UICP I have picked up another 3.7 lbs/min of airflow which should bump me up over 250WHP, easily. Car pulls like a MoFo
I know with an exhaust and FMIC I would probably be over 300WHP, but I am having traction problems as it is......freaking wrong wheel drive.
Anyway, it really depends on how much you want to spend. Here is a FP, injector, SAFC-II upgrade for $619. But you would need a logger to go with that for about another $140. So you are looking at needing about $760.
Might be easier for you to tell us how much you are planning on spending. I got my logger and SAFC-II months before I did the injectors and the FP. That way I was ready.....but it's all up to you.
http://www.extremepsi.com/store/cust...46&cat=0&page=
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-09-2005, 08:38 AM
Thanks spyderturbo for the input and for the link. I think I can put together that kit myself for cheaper than they want, but I am planning on all of that stuff eventually. I think I'll go with the 190 first, then SAFC, then injectors. It seems to be a good order that will be safe. With the 190, I can tweak boost up a little. Then I'll get the SAFC and learn to use it properly before getting the injectors and tweaking more. I already have the logger. That was definitely the first purchase after the new turbo.
