Old 09-08-2005, 04:02 PM
F22 Honda F22 Honda is offline
Send a message via AIM to F22 Honda Send a message via Yahoo to F22 Honda
Question 91 Accord Ignition Trouble
My 91 Accord does this thing every now and then where it doesn't want to start. I crank the engine and check for spark and there is none, but if I let the car sit for 30 minutes or so it will start right up. The car has new plugs and wires, and a new distributor cap and rotor. I thing its my coil that is going bad, but I thought when a coil goes bad it does not work at all. Anyone have any suggestions. Thanks
Old 09-09-2005, 04:51 PM
jtchevy355 jtchevy355 is offline
Re: 91 Accord Ignition Trouble
sounds like you main relay switch is bad
Old 09-10-2005, 12:50 AM
mpumas mpumas is offline
When coils go bad, they can do many things like work sometimes and sometimes not. Intermittent problems can be a bitch to fix. I would start with the cheap fix first- the main relay. The relays do not go bad but sometimes there are cold solder joints which could cause intermittent problems. Remove the relay and resolder all the joints which hold the relays onto the PC board. If that doesn't fix the problem, then go to the next step. Ignition Coil test, igniter test, ECU test. Check the ignition switch by checking for voltage at the top of the coil. But you are have to do the tests when the thing is not working. Keep us advised of what you find.
Old 09-11-2005, 06:17 PM
Thumbs up
Hey I replaced the ignition module and everythings seems to be working fine now. Thanks for the help.
Old 09-28-2005, 01:25 PM
ROVINGTEK ROVINGTEK is offline
Hi all,I'm having a similar problem no spark when hot or hot out with my 93 accord...where is the "main relay" and also how do I reset the ECU
Old 09-28-2005, 07:57 PM
The main relay is under the dash on the left kick panel to the left of the coin drawer. To get to it you need to remove the large module visible from under the dash. The main relay is just above it. Most times the problem is caused by bad solder joints on the relays holding them to the PC board. Just resolder all the solder points and reinstall.
