Go Back   Automotive Forums Car Chat > Buick > Regal
Old 09-08-2005, 02:54 PM
katana1981 katana1981 is offline
Send a message via MSN to katana1981
2002 Regal fog light button
I've purchase my mom's 2002 buick regal.. im very satisfied about the car.. theres only one thing that is bothering me:
During night driving, I push the fog light button to "on". Everything is working fine.. Then stopped the car and restart it again.. now the fog light is off.. but the button is in the "on" position.. I have to press it off and then on again.. Seems the button cannot hold to the "on" position.. Am I the only one who has that kinda problem or is it normal?!
Thanks guys!!!
Btw, is 30 mpg (highway-city mixed) is good for the car?!
Katana
Old 09-08-2005, 06:03 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2002 Regal fog light button
Thanks guys!!!
Katana
Unless Buick changed it in 2002, my 2001 GS and 1999 LS work normally. With the fog lamp button pressed and after a re-start the fog lamps should remian on without having to push the button again.
In the engine compartment fuse box is a fog lamp relay. Check it out. Doesn't sound like it is working right. Good luck!
Timeslip 08/12/06
AF Community Guidelines
Old 09-11-2005, 09:59 AM
thats not it.. the problem seems the button actually like it cannot hold to the "on" position cause I've tested some fuses and putted a new one... any idea what I should do?!
Old 09-11-2005, 01:07 PM
BNaylor's Avatar
Re: Re: 2002 Regal fog light button
Maybe its the fog lamp switch itself or wiring. Have you checked voltages with a multimeter. Are you 100% sure it's not the fog lamp relay or wiring up to it? For troubleshooting purposes you can switch the fog lamp relay with the horn relay and see if any symptoms changes.The relays are identical and located in the engine compartment fuse box.
Timeslip 08/12/06
Old 09-19-2005, 04:50 PM
I know the fuse box under the hood and where each fuse is located but for the relay, is this a I-can-do-it-myself action?! Just tell me what is a relay(sorry im french) and thats it.. I'm gonna switch them for sure
Old 09-19-2005, 06:21 PM
BNaylor's Avatar
Yes, it is something you can do yourself (DIY). In the fuse box under the hood, just remove the cover and there is a placard on the lid. It will show all fuses and relays. The relays are those little square objects that are either silver or black in color. There are bigger than the fuses. They are plug in, so they can be removed by unplugging. Just get a good grip on one and pull up. Also, the relays will have part numbers stamped on them. The horn and fog light relay should be the same.
The horn relay may be marked 16. The fog light relay marked 17. They will be somewhere in the middle of the fuse box.
Also since the horn relay is hot at all times, it's a good idea to disconnect the battery before switching the relays out so the relays are not damaged. Be sure to reconnect the battery before seeing if it works or if the problem is still there. Good Luck!
Timeslip 08/12/06
Old 10-04-2005, 03:03 PM
well finally what I did was very simple... instead of checking everything.. I took a little piece of thick paper and stucked it between the lower dash and the fog button itself... did an amazing job.. its unnoticeable :P thanks a lot for the advise!
