Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 09-08-2005, 12:15 PM
gmb0623 gmb0623 is offline
Send a message via AIM to gmb0623
Headlight/tail light issue
1995 Rodeo 6 cylinder. My headlights flicker and my tailight fuse blows immediately upon turning on the headlights. I've been advised to change the headlight switch. Does this sound reasonable? Any other suggestions? Thanks
Old 09-08-2005, 12:22 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Headlight/tail light issue
remove your trailer harness, if you have one.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 09-08-2005, 08:18 PM
directory's Avatar
directory directory is offline
i keep reading about the trailor harness causing a lot of problems. can one be installed without issues?
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 09-08-2005, 08:42 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Re: Re: Headlight/tail light issue
Lemme guess, now you're going to get a trailer for your spare tires.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 09-08-2005, 10:20 PM
Isuzu Guy
yup, you can install them without problems. The key is that, from time to time the need to be cleaned.
-Ryan
Isuzu Moderator
Car Show Tips
Old 09-13-2005, 01:54 PM
Gracias, Amigo
Problem solved. Turns out it was indeed a trailer harness issue, a disconnected ground wire. Thanks
