Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 09-08-2005, 10:05 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
95 HVAC problem
when i turn the fan on (any setting; ac,heat,vent,etc) air only blows out of the defrost vents. Before it would only happen periodically but now only the defrost vents are blowing air. any help/suggestions would be greatly appriciated.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 09-09-2005, 10:08 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 95 HVAC problem
check the vacuum hoses going to the round vacuum ball in the driver's back corner of your engine bay. The line going to the vacuum ball will often degrade or come loose. Replace that small section of hose with 5/32 windshield washer hose.
Also check the that the vacuum hose is connected to the back of the plenum near the passenger side of the distributor cap.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-09-2005, 11:08 PM
ZL1power69's Avatar
GM S-Series Mod
Re: Re: 95 HVAC problem
today i found that the vac hose at the back of the upper intake had completely broken in half. it was completely dryroted. i replaced it with a spare vac hose and problem solved, vac guage says 19-20lbs at idle.
Low 11 sec sleeper
My Cardomain
Old 09-09-2005, 11:14 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: 95 HVAC problem
w00t!
Great going!
Old 09-09-2005, 11:44 PM
ZL1power69's Avatar
GM S-Series Mod
Re: Re: Re: Re: 95 HVAC problem
w00t!
Great going!
again thanks for ur help.
Low 11 sec sleeper
My Cardomain
Old 09-10-2005, 12:07 AM
BlazerLT's Avatar
AF -Advisor
Re: 95 HVAC problem
My pleasure.
