| Performance Discussion about performance modifications and issues. |
RB20DET engine part
Hi,
Can anyone tell me what this part is on the intake side of the RB20DET? Don't mind the hand drawn arrow... Thanks!
Cefiro? How do you pronounce that again? |
That is the standard reciculating blow off valve.
Member of AF's Slide Squad (Member #04) Quote:
Neishlin Motors Soon to be my best friend
So if I was going to add a third party BOV would I remove this one of just uncable it?
Would the new BOV attach to any of the piping of the old BOV?
it's a pretty common fitment, i'm sure some companies make a bov that bolts right up, if not a simple adapter could be made to save you cutting holes in your pipe work. if you get a plumback it should connect to the old recirc. pipe and the standard vacuum line as per the old bov.
as cadet said, you should be able to bolt it right on. I used to have an HKS supersound bov on my soarer (1g-gt). normally, the piping is made so that you can use the stock pipe sleeves.
the only issue with BOV'S on skylines is the cause the car to stall if not set up right. cause it vent to much air to quickly (I think)
cheers meggala
check out my site http://www.meggala.com jdm info and drifting stuff nissan cefiro a31 fitted with sr20 and trust t518z turbo. 13.3 @ 105.69 mph 2.069 60' full street trim
This is my engine with a Greddy BOV. It just doesn't bolt right on and an adapter plate had to be made.
"I wash my hands of those who imagine chattering to be knowledge, silence to be ignorance, and affection to be art." Kahlil Gibran http://www.skyline-racing-tech.com |
hey forsteen your r32 manual pics on ya site arnt there anymore!
If you install a non-recirc blow-off valve it will vent air that has been metered by the AFM, hence the car will run rich and stall sometimes. You need to get a piggyback device (which name I can't remember) to fix it, or go for an aftermarket ECU and use MAP sensing instead of the AFM.
