82 22r carb problems
Please help, 82 pickup 4x4 runs great but will not start without start fluid or gas added to carb. once started runs perfect. replaced fuel filter didnt help. checked the aux accelerator pump diaphram, it is fine. thanks
Re: 82 22r carb problems
Did you check to see if the float is not saturated?
Sounds like a bad throttle pump, take air cleaner off have someone pump throttle do you see gas squirting in the carb throat if not bad throttle pump!!
