Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 09-07-2005, 11:51 PM
Drift King's Avatar
Drift King Drift King is offline
Code 65.
I pulled a code 65, O2 censor circuit. Is that the fuse? If so where is it?
EJ8
SHUMI-ROSSI-2007-F1 FERRARI DREAM TEAM
Old 09-08-2005, 03:59 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Code 65.
check ohm resistance from the two heater terminals on the o2 sensor harness (o2 sensor side). they should measure 10 - 40 ohms. if not, sensor is no good.
there should also be battery voltage with the ignition key set on the ON position (12v + or - 2 volts) on the engine wire harness side. if not, there is a break in the circuit. check connection from ecu to sensor to main relay. i dont really remember all the diagrams from the top of my head, but, i believe only the primary o2 sensor uses the main relay not the secondary.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
