Originally Posted by budda-44
Can anyone tell me how to change the ignition switch (thing key goes in) on a 1988 Camry. I have taken the plastic coverings off the steering column but cannot find a way to remove the switch. There is nothing to push to release the switch as is shown in some service manuals. Thanks for any help you could give.
Hello budda-44, the part your trying to replace is not called the ignition switch.
it is called a lock cylinder. in my haynes manual for 1983 - 1991 camrys
THE PROCEDURE FOR LOCK CYLINDER REMOVAL IS #1 to remove the plastic cover over the steering colum
#2 put the key in and turn it to accessory position
#3 insert a pin/paper clip in the hole in the casting
#4 pull the lock cylinder straight out and remove it from the steering column.
installation is the reverse of removal.
hope this helps.
good luck fixing your car.
JOET/CAMRY
