Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 09-07-2005, 10:15 PM
heavyhalf heavyhalf is offline
Angry tranny problem
my 1990 daytona (same shit as labaron) will not shift into 3rd gear it always stays in 2nd.....what is wrong with it. it is a 4 speed overdrive tranny with a 3L v6. and how come my tach works sometimes and sometimes it does not work. i here a strange noise coming from the back of my car kinda like a grinding noise.
Old 09-07-2005, 11:06 PM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
i'm not absolutely sure with the tach, it could be many things. The grinding noise could be wheel bearings, or the brake shoes dragging or something else. I know why the transmission is not shifting into 3rd. You probably have dropped the pan sometime and changed the filter. This is 90% of the time caused by the transmission sucking a little bit of air into it. this could be caused by a bad o-ring, or just not full. The only way to fix this is for one, get the air out of the system and two, take it somewhere where they have a DRB II code scanner for the transmission control module(TCM) and clear it. After this is done you should be fine. Just remember not to add anything except ATF+3, +4, or +5 (I personally use atf+3 with a bottle of lubegard atf protectant)
Old 09-08-2005, 06:34 PM
yeah i got the tach fixed.... that grinding noise is still making noise when the car is not moving and is in park. yeah with the tranny i will have to try it.
