Old 09-07-2005, 09:41 PM
Chest Rockwell's Avatar
Chest Rockwell Chest Rockwell is offline
Quickest way to reset the timing belt??
Turns out my bro's STD has spark and fuel. When we move the dizzie back and forth it sounds like it wants to start. We both figured it was probably the timing belt maybe it jumped a tooth or sumthing.What is the best way to get to the tensioner without having to remove a shit load of stuff.Maybe if anyone can give me a link to a complete walk through that could help. When we tried to turn the dizzie 180 degrees it would not slide back onto the crank. Is it supposed to do that??
If I had the extra cash I would have already bought the Helms Shopbook. AS YOU CAN SEE WE ARE BROKE ASSES.=<
Any info would help.
Hey where you goin with those two hams!?...Oh wait those are'nt hams you're just a Fat kid are'nt you Fatty?
Old 09-08-2005, 05:34 AM
j1nks j1nks is offline
Re: Quickest way to reset the timing belt??
i usualy slide the timing belt off the top gear to adjust it but you have to be verry carefull and it takes alot of strength to get it back on. i found its easter when its hot. it should still run with the timing belt off a notch just not as good. it might be something else. have you checked your marks?
Old 09-08-2005, 07:53 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Easiest way to check is to line the crankshaft pulley up at Top Dead Centre(TDC) Take the camshaft pulley cover off and it will quickly tell you whether your cam is properly synchronised with your crankshaft!
Check that you have your ignition leads connected to your dizzy in the right order too...
Old 09-08-2005, 10:06 AM
How do I check the the ignition leads? If it's the ignitor that you're talking about, I thought if you had spark then your ignitor is fine. I can't see that it would be anything else but the timing. This is a list of the things that I do have:
-Power
-Spark
-No codes
-Fuel (main relay)
-Plugs are dark coverd in oil on the fire side.but the tips are'nt worn at all.
-New cap
-new rotor. (has a little play in it, rotation wise.)
-Dizzie, when moved back and forth the car wants to start.
I would just like to make sure that it is the timing before I start pulling the car apart.
Thanks for the info.
Old 09-08-2005, 11:08 AM
Hybrid1990crx's Avatar
you said the plugs are covered in oil? just how much oil?
Old 09-08-2005, 11:25 AM
Not drenched and dripping. Enough to see that I do need a new gasket set. My dad was telling me that if you can not fit your dizzie back on at 180 degrees then something is wrong. That true?
Old 09-08-2005, 12:00 PM
vladlos's Avatar
vladlos vladlos is offline
Send a message via AIM to vladlos
maybe you got water in your fuel line or something weird like that if it isn't your timing. because i had this problem this winter and it turned out that i got condensation that froze in my fuel line or something of that sort keeping my car from starting for like 5 days.
Old 09-08-2005, 03:12 PM
I can't think of any reason for there to be water in the fuel line. We are gonna' redo the timing in a short while. If the timing is set right and it still wont start then we will be stumped for sure.
Thanks for all the info.
CROSS YOUR FINGERS!!!
Old 09-10-2005, 12:16 AM
BullShifter's Avatar
Re: Re: Quickest way to reset the timing belt??
Honda distributors are idiot proof, they only fit one way.
What was being done to the car that caused it to stop running?
Old 09-10-2005, 02:42 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Re: Re: Quickest way to reset the timing belt??
good description on the dizzy re-install.
i would also like to know what caused it to stop running.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 09-10-2005, 05:15 AM
mmcleo11's Avatar
-Power
-Spark
-No codes
-Fuel (main relay)
-New cap
The fact you have replaced the dizzy cap and rotor button, is why I ask if *maybe* you got your cylinder firing order mixed up?
Wanting to fire on a couple of cylinders and others firing wrong when rotating the dizzy is what made me think it before... 1,3,4,2 should be your order with cyl 1 being closest to the cam belt.
Old 09-10-2005, 06:29 PM
Well I kinda figured the dizzy was made to go on one way. We looked like a couple of cavemen foollin with a computer. As far as the firing order is concerned it's right on the money. My bro was hauling major ass when the car puttered its way to a hault. Fired it up made it to the driveway. It dropped dead right as he made it into the parking spot. been there ever since...(3 weeks now)
Thanks.
Old 09-11-2005, 12:14 AM
Does it have any codes?
Lift passenger carpet up - foot area
Turn turn key on
Count blinks
Old 09-12-2005, 10:55 PM
No codes at all. Just the one *blink* to let you know the ecu is running. It was raining out this past weekend so I could'nt work on the timing belt. This blows.
Goot any other ideas of what it could be??
Thankz.
