Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-07-2005, 09:32 PM
shawnira shawnira is offline
Thermostat???
I have a 1991 S10, and the temp. gage is pegging higher and higher. I suspect the thermostat. Is it any harder then "the old" ones to replace...or through out? I live in california, and have always left them out when I had a temp problem.
Any "need to know" info. before I pull it....throw it... and reseal the fittings?
tym
Shawn
Old 09-07-2005, 10:37 PM
whitetrash982 whitetrash982 is offline
Send a message via AIM to whitetrash982
dont just throw it away , get a new one , its less then 5$ for a new therm and gasket , and you want to have it in there , so the engine actually reaches operating temperature, youll also save gas by leaving it inn , cuz when the computer thinks its cold , it gives it more gas , but other then that , it could also be your radiator plugged up , or could be a fan clutch thats just not workin as good anymore , coudl even be the fins in the water pump eatin away. theres more the one part to the cooling system
Old 09-08-2005, 10:23 AM
OverBoardProject OverBoardProject is offline
Banned
Re: Thermostat???
Whitetrash is right, If I was you I would use a prestone flush when I changed the thermostat, and hope for the best
Old 09-09-2005, 10:58 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Thermostat???
Also replace the rad cap.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 04-13-2008, 05:17 PM
brakedust brakedust is offline
Re: Thermostat???
Similar problem, as I have replaced the thermostat, and the radiator cap. The radiator has been flushed, and the water pump said to be working fine, according the the attendant.
I find when it gets above 60 degrees outside, the temperature go above 210 while on the highway for any length of time. (My drive 1s 50 miles to work)
So, I see someone suggested the fan clutch may need replaced.
How would you know by looking, and do you need to remove the belt to replace it.
1991 s-10 2.8L v-6 no a/c standard transmission
Old 04-14-2008, 03:35 AM
16th hippy 16th hippy is offline
Re: Thermostat???
mine usually runs at 200-210, always steady, fresh coolant+water pump, and still same.(water pump blew through the weephole).
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 04-14-2008, 11:28 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: Thermostat???
Thread is over 2 years old. Please use your existing thread, now in the problem diagnosis section.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Closed Thread
