Old 09-07-2005, 06:21 PM
poordudewhowantcar poordudewhowantcar is offline
Send a message via ICQ to poordudewhowantcar Send a message via AIM to poordudewhowantcar Send a message via Yahoo to poordudewhowantcar
90 civic wont start
replaces alt starter and all fuses uderhood and in cabin.
any ideas ? ? ? ? (it wont turn over)
Old 09-07-2005, 09:05 PM
slipknotcraig133 slipknotcraig133 is offline
Send a message via AIM to slipknotcraig133
Re: 90 civic wont start
are you getting power at all. Check your relays. Are you throwing any codes? Check grounds. Also check the battery and the power and ground for that.
Got the car 1400
Need an H22a4 4000
Some Goodies to go Along With it 2000
Some Drag Slicks 750
Going to the Strip and Make V8's Say D*** Hondas PRICELESS
Old 09-07-2005, 09:55 PM
Chest Rockwell's Avatar
Chest Rockwell Chest Rockwell is offline
That happened to my civic a few months ago turns out it was my negative battery ground. What do you hear? Are you just getting a clicking noise? If so it could be a defective starter. Hope you get it fixed.
Hey where you goin with those two hams!?...Oh wait those are'nt hams you're just a Fat kid are'nt you Fatty?
Old 09-08-2005, 12:30 PM
ill up date soon prob like monday (8-12-05)
cars at a friends house so check back up to help me out. Thanx
Old 09-08-2005, 04:35 PM
j1nks j1nks is offline
run a new starter signal if you have to just install a button
Old 09-11-2005, 02:45 PM
pionneer_2006 pionneer_2006 is offline
Send a message via AIM to pionneer_2006 Send a message via Yahoo to pionneer_2006
my 89 civic hutchback has a starting problem , the engine is craking but there is no sparck in the distributer wire. please can u give me an answear? thank you.
Old 09-12-2005, 03:45 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
i would first check to make sure there is power getting to the starter and take off the groudn and clean with a wire brush. then i would be a remote push starter so that why you can see if its the solenoid or not. doesnt matter if its new it still could be bad. if that works then you know its either your signal or your solenoid, gets more tricky after that
Team Lonely Drivers
