Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 09-07-2005, 06:11 PM
perrenial151 perrenial151 is offline
clutch pedal feels too easy
I just re[laced my clutch with a stock regular clutch. The drives fine but the clutch pedal feels way too easy (light) than before. I bled the clutch fluid too. Is this normal? Will it tighten up with time? What could be wrong?
Old 09-07-2005, 06:36 PM
coolbone28 coolbone28 is offline
Re: clutch pedal feels too easy
could just be the stock pressure plate is a little lighter feeling. if there was a major problem like it not being bled enough then you would probably have trouble with it returning all the way. i just recently replaced my clutch and it felt different (softer) than the old clutch...but it bites a hell of alot better.
Old 09-07-2005, 06:48 PM
240SXSlideStar's Avatar
240SXSlideStar 240SXSlideStar is offline
Yeah, the stock clutch fels incredibly light, there's no pressure at all, it's normal, but annoying.
-Jonathan
JDM Racing Motors inc
Montreal, Canada
www.jdmracingmotors.com
Old 09-07-2005, 07:36 PM
wotandsdwys wotandsdwys is offline
I put a spec stage 3 clutch in my ka24de.
for a while it felt really light compared to my old act stage 1.
But after a while, it just kinda tightened up. I didn't realize it until I was thinking about how much it sucked, then I hop in, and realize that it's much tighter that it used to be.
I say wait a while for it to break in completely, mine took about a 1k miles.
But maybe thats just how the clutch was when it was brand new, and it got stiffer over age, when you bought it.
thats just my 2cents.
Old 09-07-2005, 09:12 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Do this, bleed the system well, fill with good brake fluid, and install one of these clutch lines. The clutch should feel pretty good after that. But just the loop modification works very well. And make sure you bleed it well after that. Air bubbles can be a PITA.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 09-07-2005, 11:10 PM
240SX Guy
No you don't have to bleed the fluid after replacing the clutch.
ACT does give a slightly stiffer feel. I like a stiff clutch.
That damper box does give a mushy feel to the clutch tho. I recommend removing it for ease of a system. Less things to go wrong. Plus bleeding is way easier with it gone.
-Cory
12.6@122mph
Old 09-07-2005, 11:43 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Re: Re: clutch pedal feels too easy
MF Werd.
