Old 09-07-2005, 06:09 PM
dlbdata dlbdata is offline
95 Escort 1.9LX Idle Surge
My 1.9L just started doing this a couple days ago. When the car is idling in neutral or in park, the idle speed constantly surges up and down. It seems to be especially worse when I put my foot on the brake, sometimes when I take my foot off the brake it stops surging. If I put it in gear (drive or reverse) the surging stops. I checked for vacuum leaks and replaced one hose, but no different. It seems fine when driving it.
I've recently (10k-15k miles ago) given it a tune up, new plugs, air filter, timing belt.
Any ideas?
Thanks in advance.
Old 09-07-2005, 08:23 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: 95 Escort 1.9LX Idle Surge
Any ideas?
Thanks in advance.
I think there is a vaccum leak but look up how to clean the IAC in this forum
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 09-09-2005, 06:37 AM
Re: Re: 95 Escort 1.9LX Idle Surge
Thanks. I'm going to take a close look at some of the other hoses, etc, and also try cleaning the IAC & MAF sensors.
Old 09-09-2005, 08:15 AM
chevyn0va1's Avatar
Re: Re: Re: 95 Escort 1.9LX Idle Surge
let us know how you make out
Old 09-11-2005, 06:15 AM
Re: Re: Re: Re: 95 Escort 1.9LX Idle Surge
Had plans of checking it out this weekend. I filled up with gas Friday night, and it seems like the problem went away. Maybe a bad batch of gas? Will have to wait and see if the problem returns.
Reminds me of when I was a kid and filled up my old AMC Green Hornet. Got up the rode about a mile before the car died. After draining the tank I realized I ended up getting 8 gallons of nasty looking swamp water.
Old 10-02-2005, 06:01 AM
Any ideas?
Thanks in advance.
I'm just following up with the fix for this problem.
I was having the up & down idle problem when I came to a stop. I tried taking the IAC off and cleaning it. I probably made a mistake in using WD40 (too strong a cleaner or maybe the lubricant in it caused problems?), and it actually seemed to make the problem worse. So I went out and bought some CRC Throttle Body&Air Intake cleaner (says it is safe for teflon coated parts). I sprayed this into the throttle body (took air intake hose off) while revving the engine up & down. Also sprayed some of it up into the holes in the throttle body that lead up to the IAC. This seems to have fixed the up&down idle problem.
Old 10-02-2005, 04:48 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Hope it's fixed. Sure sounds like a vacuum leak to me....
Nevada Tumbleweed
Old 10-05-2005, 05:38 AM
Yeah I hunted everywhere for a vacuum leak but couldn't find any. Cleaning the Throttle body/IAC with the CRC Throttle body & Air intake cleaner did the trick. Thanks.
