Boy has a 1996 buick LeSabre: He is away at college and it would take some time for dad to get out there. For two days now this symbol comes up on his dash:
http://img161.imageshack.us/img161/2033/pic7mr.png Now I have a 93 PA and I do NOT have this symbol ? Did this symbol replace the words "Check Engine" Is that the Check engine symbol ? Second question: I know on some cars you can jump certain plugs to pull the codes off of the car, can you do this with the 96 LeSabre and if so how do you do it ? thanks Cobra |
Re: Check engine light ????
Yep, that is a check engine light! On a 96 you need a scanner to retrive the codes. Tell him to take it to an Auto Zone and have it done for free.
Put the cap on. Sometime when the car is lukewarm and it restarted the system will pressure test the tank again and see how fast it bleeds down. If it doesn't leak too fast, the light will go off. On my 98 this came on and it turned out to be a rubber tube to the charcoal canister under the computer under the air intake in the engine compartment. The dealer found it. The end of the tube had "rotted" away. $44. |
Re: Re: Check engine light ????
light still on |
Re: Re: Re: Check engine light ????
Resolved
It ended up being a guumy EGR valve. Mechanic cleaned it out and check engine light is off. Don't know for how long but it's off.
thanks |
