Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 09-07-2005, 06:00 PM
mikehults mikehults is offline
94 Wrangler gassing-up problems
I own a 94' Wrangler, 2.5L/4Cyl. I have been having problems for the past few years while fueling the vehicle. The automatic gas nozzle cut-off (Gas Station), regardless of gas tank level, "cuts-off". I have tried different gas stations, different octane levels and different positions of the gas nozzle. None of these seem to help. It now takes me 10 minutes to fill the 13 gallon gas tank. Any suggestions?
Old 09-07-2005, 08:19 PM
chibears85 chibears85 is offline
I had the same problem with my yj, and you just gotta push it in real hard, and then make sure that you hold it in there, cause ive had the license plate push the nozzle out before....not good
Old 09-09-2005, 12:04 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 94 Wrangler gassing-up problems
You might want to check to make sure there's no obstruction in the fuel filler nozzle on your Jeep. I've had my share of "early clicks" at the fuel pump, but in every case have been able, as you say, to turn the handle or pull it out a little to make the problem go away.
Has it always been like this or has the problem developed recently?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 09-09-2005, 10:45 PM
Jeepins Jeepins is offline
I've had a similar problem with my '98 Wrangler. The new vapor recovery nozzles seem to 'trap' vapors a bit too much where the nozzle is and cuts off the fuel flow as if the tank is full. I've had to cock the vapor recovery attachment on the fueling nozzle a bit so it will fill at normal speeds. Has happened at about 1 in 10 gas stations, depending on how new their pumps are.
Old 09-19-2005, 04:23 PM
lucky1979 lucky1979 is offline
once i put the body lift in my 94 i have the sa,me problem but have found if u pull the nozzle out about an in. and turn it towards the tank it's not as bad
Old 10-05-2005, 11:19 AM
DanDSN DanDSN is offline
Send a message via MSN to DanDSN Send a message via Yahoo to DanDSN
I had the same problem with my old jeep. It was a 93 Wrangler and I somehow crushed the vents on the top of the fuel tank. Because the vents were crushed it would build up pressure in the tank and cause it to shut the pump off way to soon. I now own a 95 and haven't had a problem. Hope this helps
Eat, Sleep, and Jeep
Dan
