Old 09-07-2005, 03:43 PM
memememe99 memememe99 is offline
injector cleaners
well after alot of time and money i have found out my problems with my gp is a clogged injector.i thought about sea foam agin but does it really work that well?i just heard of some cleaning system from a car dealer here where they run cans of somthing through your fuel system have any of you heard of this?and would it be better than using sea foam?thx
Old 09-07-2005, 05:06 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: injector cleaners
For cleaning specifically fuel injectors, if it's minor, I would run a bottle of concentrated lucas cleaner through it. But if its to the point where your actually experiencing fuel shortage / richness / misfiring, ect. I would deffinately have them professionaly cleaned. A dealer or shop (shops are much cheaper) can do this. They usually offer an injector cleaning, a fuel system cleaning, and both. I would get both. They hook your entire fuel system up to a solution they have and run it off that - it cleans everything superbly. Yes; it would deffinately be better then seafoam. To have the entire system professionaly flushed / cleaned at a shop will run you anywhere from 75 to 100 $; but is deffinately worth it. You can't beat it.
Old 09-08-2005, 06:32 AM
thank you it is to the point where we are getting problems i believe it is rich and gas may be getting to the cat plus it uses a quarter tank to drive 35 miles thank you agin
Old 09-08-2005, 03:24 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Ridenour, pour in treatments work nicely to prevent problems, but are virtually useless once an injector gets clogged. The in-shop treatments use a pressurized system and clean the injectors much more thoroughly.
Old 09-08-2005, 03:28 PM
gbic1 gbic1 is offline
Seafoam works very good and should be used as maintence. A good shop will have a cleaner that hooks directly to the fuel rail to clean the injectors. The can type that goes into the pressure test port is not very good and just a good way to clean out your wallet.
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
Old 09-09-2005, 01:17 PM
thx guys i had it done yesterday and it was a little rough at first but this mornin it drove like brand new ty agin
