Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-07-2005, 12:53 PM
RedDrag0n RedDrag0n is offline
Send a message via AIM to RedDrag0n Send a message via MSN to RedDrag0n
91 5.0 V8 stalling after engine start
I have a 91 T-Bird with a 5.0 V8 and after i start the car, it runs at 1200 RPM, then it drops to 700 RPM. After a bit, it sounds like the engine is having problems with gas (but it's a full tank) and she dies. Any ideas on how i can fix it? Maybe up the idle?
Old 09-07-2005, 04:49 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: 91 5.0 V8 stalling after engine start
Don't mess with the idle. It is designed to do exactly what you describe.
How long does the car have to sit before you can start it again? Silly question but really low coolant can cause your problem.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 09-08-2005, 02:04 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
check also your throttle body, make sure you don't have any built up carbon on the throttle plate and in the area for the idle speed motor, get some carb cleaner and clean off any excess carbon that maybe built up.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 09-08-2005, 03:06 AM
Re: Re: 91 5.0 V8 stalling after engine start
Immediatly right after it dies, i can restart the car, and it will do the same process over again. As for the coolant, it's full. I did the main checks for a solution for the problem, but this one has me stumped.
Where do i look for that? since is my first t-bird, but not the first ford.
Old 09-08-2005, 05:27 AM
look inside your throttle body for black carbon that has been building up over the years. You should also notice an indentation or a dimple area in the throttle body, that's designed for the idle speed motor to allow air to bypass the throttle body, make sure it does not have an excessive build up of black carbon deposit on it as well, that could lead to problems during idling.
