Old 09-07-2005, 11:53 AM
sLADe781 sLADe781 is offline
Gapping
So I did a search and a lot of threads talked about the gapping of spark plugs but none about how to actually do it. Seeing that I've never gapped a plug before, can someone explain it to me? Hehe We have this coin like thing that my dad gave me that measures the gap but do I just keep pushing it up to gap it?
Old 09-08-2005, 01:39 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Gapping
ya, its almost fool-proof. wedge that coin in there to increase the gap. or you might pry the electrode on the spark plug up first with a screwdriver, then find the correct gap value, and kind of 'hammer' the elctrode down. it shouldn't take much to move the electrode. i've seen people just tap it on the concrete.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 09-08-2005, 09:18 AM
Re: Gapping
Wow....that sounds kinda rough. Wouldn't that damage the tip?
Old 09-08-2005, 10:14 AM
Linebckr49's Avatar
Re: Gapping
no, it does not damage the tip. how else could anyone move the metal tip? you MUST bend it, its that simple. now you might not want to hammer it, but rather just tap it on something hard til the tip is at the correct gap. think about it, gapping is only changing the distance the electrode is away from the tip by a few hundredths of an inch. so no, you won't damage it by bending a little piece of metal that tiny amount. just try it. or ask your pops how he would gap a plug.
93 3000GT base
