Old 09-07-2005, 09:57 AM
kirtap kirtap is offline
Question how to check Gaz pump
Hi,
i have a Plymouth Voyager 93, 3.3L.
When i put the key on ignition witout starting the motor, i don`t hear the sound of my gaz pump.
i would like to know how to check if the electricity is going to my gaz pump without taking off my tank.
thanks,
Patrick
Old 09-07-2005, 08:46 PM
89ltd 89ltd is offline
Re: how to check Gaz pump
are you saying the van doesn't run right now? or you just can't hear the pump?
Old 09-07-2005, 10:54 PM
waltham41 waltham41 is offline
under the left side under the van along the frame should be the wire loom that goes back to the gas tank for power and the gauge. just forward of the tank along the frame is a connection, unplug it and see if any of the contacts that come from the front have power to them with the key on.
Old 09-08-2005, 08:51 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
if your car starts, then you have no problem
if it doesn't, check the fuel rail for preasure, if there isn't any then do what waltham41 said in his post
