Old 09-07-2005, 07:46 AM
jft7032 jft7032 is offline
Rough running and missing power
Folks:
This is my first post to this forum, and I am glad you folks are here. I would appreciate your good help in diagnosing my problem. I am strickly of the "shade-tree mechanic" variety with real specialized mechanical knowledge.
For a couple of months now my '90 S-10 pickup (6-cylinder, 2.8 liter engine, fuel injector) runs increasingly rough; I can still drive around but the problem is becoming more pronounced. When I first start the engine, it will run perfectly smooth for about ten seconds, and then it dips down into a seemingly gas-deprived idle. It may or may not die on me, something it had never done before.
I have changed the fuel filter, plugs and SP wires, air filter and PCV value. (Haven't checked cap and rotor, though.) Poured two bottles of Lucas fuel-injector additive down the tank but still no smoothing out.
What is my next diagnostic step, please?
jft7032
Old 09-07-2005, 09:58 AM
OverBoardProject OverBoardProject is offline
Banned
Re: Rough running and missing power
check the fuel pressure, your pump or fuel regulator might not be up to snuff. Also try to loosen off gas cap just in case it isn't venting properly.
Then check cap and rotor.
Old 09-07-2005, 12:21 PM
Overboard Project:
Thanks for you suggestions; will do what you advise.
Originally Posted by jft7032
Folks:
jft7032
Old 09-09-2005, 11:02 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Check your timing with the timing wire disconnected from the PCM under the glove box.
http://www.automotiveforums.com/vbul...d.php?t=453371
1995 Factory Blazer Service Manual for sale, PM if interested.
