Go Back   Automotive Forums Car Chat > Subaru > Legacy / Liberty / Baja
Old 09-07-2005, 06:53 AM
bertmaster2000 bertmaster2000 is offline
Question Check Engine Light - '97 legacy
I recently bought a 1997 Subaru Legacy Outback Limited Wagon with a 2.5 L and auto trans. it has 120K miles.
i was occasionally experiencing a slight hesitation during acceleration so i added chevron with techron fuel additive to the last tank of gas to clean-out varnish and carbon deposits from the fuel system. about halfway thru that tank of gas the check engine light came on. i had autozone read the code and apparently their code reader indicated the catalytic converter has decreased efficiency.
the autozone employee that read the code for me recommended i run a tank of premium unleaded gasoline and add octane booster to help clean-out the deposits that have collected in my catalytic converter. will this work or is he full of it?!?!
replacing the converter is expensive so i don't want to do that unless its truly necessary.
Old 10-11-2005, 09:55 PM
rustylane rustylane is offline
Send a message via Yahoo to rustylane
Re: Check Engine Light - '97 legacy
You can try that but I doubt it will work. I put a hose up my tail pipe and washed it out. That helped alot.
Old 10-22-2005, 02:51 AM
naut1648 naut1648 is offline
hahaha
run on hi-octance fuel and a octane booster try it
you need the fuel anyways so it isnt that expensive
Old 10-22-2005, 04:51 PM
Vidar Vidar is offline
Re: Re: Check Engine Light - '97 legacy
I'm glad youre feeling better
