Old 09-06-2005, 10:33 PM
RKLamb RKLamb is offline
Turbo Question
Can you take the turbos off of a TT or a turbo eclipse and mount them to a non-Turbo Stealth. I have an Eagle Talon AWD sitting in my yard that I am about to strip and I was wondering if I could put the turbo from it on a non turbo Stealth.
Old 09-07-2005, 01:06 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: Turbo Question
You could, but it would cost you quite a bit of money and a custom setup, and it wouldnt really be worth it.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 09-08-2005, 08:47 PM
Hotshot8792 Hotshot8792 is offline
definitely could not run a single turbo with a DSM turbo on these cars. If its a 1st gen, those are just enough to be a slight upgrade for a TT for one of the turbos. If its a 2g DSM, you'll be lucky to make positive pressure with it on these motors.
Now you can do a TT conversion, which would require every part on the vr-4 related to make a TT, then if its a 1st gen manual turbo, then you could either get a TD05 kit, or adapter plates, and find yourself one more turbo, or if its a 1st gen automatic, just swap out turbine housings in which you might have to bore out the 3/S housing a little, and you can run a 13g/9b combo, or if its a 2g turbo, still not worth it lol. But yea, other than that, what talskinyguy said.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
