Old 09-06-2005, 07:56 PM
JaceWade JaceWade is offline
'71 Ventura II won't go forward
I got my hands on a '71 Ventura II. It has a 307 in it, automatic. But it won't go intro drive. Well it will but it doesn't move. When I put it into reverse it goes backwards, but when I put it into 1st, 2nd or drive it doesn't move. Anyone have any idea where the problem is? Other than the tranny being screwed up?
Old 09-08-2005, 08:26 AM
MrPbody MrPbody is offline
AF -Advisor
Re: '71 Ventura II won't go forward
The forward clutches in the transmission are fried. You will need to rebuild it. It should be a TH350.
Old 09-08-2005, 03:20 PM
rebuild it...i hate those words. Thank you
Old 09-09-2005, 04:37 AM
NOVA71's Avatar
NOVA71 NOVA71 is offline
You could try checking to see if it's low on tranny fluid. This would cause slipping. If it's not low, chances are it's fried.
Current Rides:
1971 Nova
2004 Tracker
2013 Sonic
Past Rides:
2007 G5
1984 Firebird
2000 Jimmy
1994 Jimmy
1990 Tracker
1985 Jimmy
Old 09-09-2005, 02:34 PM
yea its fried then, it has fluid
Old 09-09-2005, 03:09 PM
NOVA71's Avatar
The good news is that a TH350 tranny is relatively cheap to rebuild. They are also plentiful and usually pretty tough.
Current Rides:
1971 Nova
2004 Tracker
2013 Sonic
Past Rides:
2007 G5
1984 Firebird
2000 Jimmy
1994 Jimmy
1990 Tracker
1985 Jimmy
Old 09-15-2005, 07:59 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
I had a '77 Caprice winter beater than did the same thing. I had gone 20 years without a transmission service. I changed the fluid and filter and it worked normally.
The filter was blocked by lots of debris, which reduced trans fluid pressure too low. For some reason, it lost forward gears but reverse still worked.
I would suggest try that first, it might work, and its a lot cheaper than a rebuild.
However, I do agree with Mr Pbody, the trans will likely need rebuilding.
