Old 09-06-2005, 05:34 PM
j1nks j1nks is offline
crx d16z6 swap distributor help
i put a d16z6 in my crx with the stock crx intake and distributor it loses power around 5000 rpms. what should i do?
Old 09-07-2005, 08:04 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: crx d16z6 swap distributor help
First, welcome to the forum...
Second, do you have a dx, hf or si? It matters if you wired for mpfi or already were. You need an mpfi distributor from an Si. Did you wire up vtec?
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 09-07-2005, 04:49 PM
i used si intake distributor and wiring harness
Old 09-07-2005, 04:59 PM
how did you get the distributor to fit right?
Old 09-07-2005, 05:03 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
cut notches in the holes where it bolts up so you can bolt it up right.
or you could get thick L brackets made with holes drilled through the long part and it would latch down on the tab of the dizzy..if that makes any sense but its easier just to notch it.
2002 Acura TL Type S
1991 Honda Crx Si
Old 09-07-2005, 08:31 PM
will it run right if i do that or is there another reason it looses power at 5000 rpm?
Old 09-07-2005, 08:36 PM
do you use all 3 bolts?does anyone have a pic?
Old 09-07-2005, 08:46 PM
can you pull the tranny without pulling the motor?
