Old 09-06-2005, 04:30 PM
JohnFrisco JohnFrisco is offline
92 Accord Lx--How to remove Driver's Kick Panel
I am replacing my Main Relay.
I can't get the driver'skick panel off. It had one screw that I removed. How far am I supposed to pull it out? I don't want to break the clips.
Thanks!
Old 09-06-2005, 05:51 PM
It feels like it is going to break if I pull too hard.
Old 09-06-2005, 06:22 PM
AccordCodger AccordCodger is offline
Re: 92 Accord Lx--How to remove Left Kick Panel
If it's the one I think you mean (covering up the fuses) then mine wasn't even held with screws. I think it had a plastic turn latch (can't tell you any more - the car's gone).
Old 09-06-2005, 06:29 PM
Re: Re: 92 Accord Lx--How to remove Left Kick Panel
You are thinking of the fuse box panel.
Here is a picture of it.
Old 09-07-2005, 02:46 PM
mpumas mpumas is offline
You don't remove the kick panel to remove the main relay. It is above the inside fuse box and above another larger module that you have to remove to get to it. It is held in with one screw and the connector.
Old 09-07-2005, 05:46 PM
Ummm - where did the main relay creep in? He didn't mention that.
OK - then the panel is probably anchored under the door sill plastic. (I hate the way you have to take off a whole string of things to get where you want. I once had to remove the gear shift lever to replace the right rear tire )
Old 09-07-2005, 05:47 PM
Oh, wait, sorry you DID mention the main relay. Go with what mpumas says.
Old 09-07-2005, 05:55 PM
Okay I brought it to my mechanic and he put in a new relay.
He had a hell of a time too! He couldn't get the panel off either. I am talking about the big panel below the steering wheel. It has one screw to remove, but when you try to pull the panel off the two clips wouldn't let go. Here is a picture of the panel.
My mechanic managed to remove the Main Relay, somehow without removing the panel. It's a tight fit in there.
I apologize for calling it a kick panel--my bad
Thanks for helping out!
John
