Old 09-06-2005, 03:37 PM
mickbench's Avatar
mickbench mickbench is offline
Tamiya TS-7.. I hate this stuff..
OK. I do not like Tamiya TS-7 Racing white... I, th fool that I am only brought one can.. Yes one can to cover my Honda F1 car I'm building. Thought this would be plenty. I primed the body white, smoothed this down, and then washed.
I applied the first coat of white TS-7, first coats were a few mist coats. I then applied a more heavy coat to start building the paint up, it's done nothing... It's like I sprayed the entire can (that is now empty) into the air..
And, get this - I've got runs all over the place.. OK, before some one says you sprayed too close, I didn't... I did nothing that I've not done for the last six models I've built.. I thought Camel Yellow by Tamiya was hard - this is just a nightmare. And the paint has gone nowhere after just three mists and one buildup coat, and I've got runs, and the paint looks like mat..!! This isn't right.. I think this can wasn't right.. The paint I think was off. It has dulled so much, I've seen mat paint with more shine.
Not impressed with this at all... I've now got to sand the parts and see if the runs do not affect the paint already down, buy more Tamiya TS-7 and lay more mists down and then try again for a glossy coat...
All this for one LITTLE body.. It's not a big car I'm painting.. In a mood now..!!
Old 09-06-2005, 03:56 PM
Zurbert82's Avatar
Zurbert82 Zurbert82 is offline
Very strange, I had no problems at all with TS-07 and my RA272. I doubt I was as experienced as you are, so maybe you just lucked out with a shitty can?
Anyway, I hope this can provide a little inspiration although it is box-stock...
RA272
Old 09-06-2005, 04:15 PM
Eric Cole's Avatar
Eric Cole Eric Cole is offline
Re: Tamiya TS-7.. I hate this stuff..
Strange, I've had good luck with the TS-07 racing white also. Nice and glossy with good coverage painted on a 1964 Ford Thunderbolt.
I'm not sure what went wrong, the matt finish issue sounds like a high humidity problem. So many things can affect paint...
Eric Cole
Other Model Pictures Here:
http://s5.photobucket.com/albums/y197/justdande/
Old 09-06-2005, 04:18 PM
blueboost's Avatar
blueboost blueboost is offline
same thing happened to me. Its either too little or too much with that color.
Old 09-06-2005, 04:27 PM
mickbench's Avatar
I think I can sand the runs out. It's drying pretty flat now, and I'll go and get another can, to even the coverage.
Can''t understand how it used so much paint though..!! Small parts I guess. Small parts are wasteful on paint.
Still, sand out the runs and try again. It should't need a strip, it was the matt finish I was more of a mood about. Runs can be flatted and polished out, but no shine at all...!!??? Well I give up on that..
mickbench's Avatar
RA272
Nice build.. How many cans of TS-7 did you need..??
Old 09-06-2005, 04:32 PM
HHugo's Avatar
HHugo HHugo is offline
It's not an easy colour, because the paint gives very poor coverage. I must have given my in-progress Ra272 at least a hundred coats of TS-7 (so to speak )
No problems with dull paint though...
Old 09-06-2005, 04:43 PM
mickbench's Avatar
It's very high humidity where I am tonight. Just checked. The front nose and rear panels have just been dunked in brake fluid. I'm not even going to attmept to fix them, I thought about it, but nope.. Re-spray.
I'll get a couple of cans and try again...!! This bloody Tamiya TS paint. Everytime it's a nightmare..!!
Thanks all... This is just a classic case of - IT WENT WRONG..!!
Old 09-06-2005, 05:13 PM
Layla's Keeper's Avatar
Layla's Keeper Layla's Keeper is offline
Supermodified
You probably would've been better off using Model Master's new lacquer line. I've found that their rendition of Ford's classic Wimbledon White is not only much better for 60's era cars' shade of white, but lays down more evenly with less trouble.
It's a two stage paint, so just pick the clearcoat of your choice and you'll never have an issue.
Proud Owner/Operator of Haven Raceway and Hobby!
Old 09-06-2005, 05:41 PM
Zurbert82's Avatar
Just 1.. I got a run or two on the nosecone but thankfully it isnt too noticable.
Old 09-06-2005, 06:08 PM
Fkouch's Avatar
Fkouch Fkouch is offline
That'd be good but we can't get Testors stuff in the UK
Mick, couldn't you go down to Halfords and get it colour matched there? I'm sure automotive paints give better coverage.
Cheers
Farrokh
Current Projects
Yamaha YZF-R1 Taira 70% complete
Lamborghini Diablo SE30 (Fujimi/Revell combi) 20% complete
Tamiya Ferrari Enzo plus SMS, Sakatsu and Acustion 10% complete.
Old 09-06-2005, 06:11 PM
ZoomZoomMX-5's Avatar
I've had great results w/TS-07, no problems at all. Same w/Testors Wimbledon White, one of few Testors lacquers that isn't complete shite (don't bother with the metallics unless you want metalflake like a bass boat).
My Fotki Album
Old 09-06-2005, 06:45 PM
ImolaEK's Avatar
ImolaEK ImolaEK is offline
Sounds interesting. I was going to try TS-7 a while ago for a Honda (looks a bit like Championship White) but i decided to paint it black. Good thing i didn't use it, or else i would've problably had a headache also Only times i have had problems with cans have been when Humidity is too high or when i haven't shaken the can enough. Or it could just be you got a little unlucky and recieved a poorly done can? Somtimes it isn't your fault. I'd just get another can and pick up from where i left off Don't let this silly color/(can) ruin your on-going progress
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
www.myspace.com/joeham
Old 09-06-2005, 09:49 PM
Hawk312 Hawk312 is offline
I feel your pain! I emptied several cans of Tamiya Yellow (I forget which TS#) on a single body before I gave up. Even with heating the can and very light mist coats, the edges underneath were still visible. For me, it`s been hit or miss with Tamiya sprays. Some are wonderful, some suck. Their clear seems to burn through the color coats pretty easily, even after 24 hours dry time.
I like Testor`s laquers I`ve used so far, and I agree with the comments on Wimbeldon White. The car below was painted with Testors laquer colors with no issues. The `Cuda in my signature was also sprayed with Testors Laquer.
WANTED! 1/12 Corvettes and Camaros.
Newest builds. Click on images to go to the thread:
1/12th `69 Z/28 Camaro and 1/12 `67 Corvettes
Old 09-06-2005, 11:06 PM
MidMazar's Avatar
MidMazar MidMazar is offline
I've never had problems with it, and have used it 3 times so far on bodies, i don't know what to say, maybe the paint was defected or the nozzle was messed up. Hopefully you solve ur prob.
In Progress
