View Poll Results: Pick my airbrush
Iwata Revolution BCR- (bottom feed) 4 12.12%
Iwata Revolution CR- (Gravity feed) 13 39.39%
Badger Crescendo 175-7 4 12.12%
Badger 360 2 6.06%
Other 5 15.15%
Iwata Eclipse HP-CS 5 15.15%
Voters: 33. You may not vote on this poll
Old 09-06-2005, 03:35 PM
blueboost's Avatar
blueboost blueboost is offline
Pick my airbrush (poll)
After years of modeling, I feel like the only thing left that I cannot do to my satisfaction is lay paint on the body like a pro. I always get inconsistancy's, and quite frankly, I'm tired of it. Its time for a nice airbrush. I've spent a few hours on here researching. I've narrowed the playing field down to your most recommended. I would like you to vote on which you think I should purchase.
both utilize a Teflon packing needle seal, which is impervious to solvent-based paints, and is easily replaced.one tip and one needle do it all. dual action, internal mix.
Dual Action, Internal Mix, Siphon (Bottom) Feed. PROBLEM- have to change tips. (if you vote for this model, please specify why you like it better then the other choices)
Badger 360
Offering Gravity AND Bottom Feed! Dual Action, Internal Mix. Single needle/tip/head assembly. I like the thought of this one the best.
Old 09-06-2005, 04:04 PM
mozli's Avatar
mozli mozli is offline
Re: Pick my airbrush (poll)
In my opinion you've overlooked the best one..
Iwata Eclipse HP-CS
finished: BRG Morgan 4/4
RoY
Old 09-06-2005, 04:12 PM
blueboost's Avatar
Re: Re: Pick my airbrush (poll)
Iwata Eclipse HP-CS
Moderators please add that selection to my poll. I didn't see much about it in my searches.
Old 09-06-2005, 04:24 PM
D_LaMz's Avatar
D_LaMz D_LaMz is offline
I was going to get a Revolution CR but I don't really need it right now CR is good for a small amount of paint and BCR is good for large amounts because of its big jar. Theres also a comparison chart on Iwata's site.
Old 09-06-2005, 06:11 PM
Merkava's Avatar
Merkava Merkava is offline
Send a message via AIM to Merkava
Definitly add the HP line from Iwata. I use the HP-C, and I love it to death.
The name is Sam.. and I'm ready to rock
TRIUMPH!
Old 09-06-2005, 06:34 PM
ImolaEK's Avatar
ImolaEK ImolaEK is offline
I suggest any Iwata I use an Iwata Eclipse HP-BCS and it works wonders. Good for art and models. But yes, the Revolution CR would be my pick for your airbrush Very economic and a all around good airbrush. Badger is alright in my opinion, the badger i have is a little stiffer than my Iwata. I find my Iwata more easy to use and comfortable.
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
www.myspace.com/joeham
Old 09-06-2005, 07:25 PM
blueboost's Avatar
I made this nice little pole for you all to use, but no.. You have to ignore it. Es ok!
I'm into this Eclipse HP, lets see if anyone else chimes in. This board seems semi-dead since I used to frequent it last.
Old 09-06-2005, 08:22 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Wow, that was hard *sarcasm*.
Added your poll position.
EDIT: I almost forgot, that will be $5 USD
-Mike
Old 09-06-2005, 09:00 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Pick the one you want. The model of airbrush you buy is not going to effect the quality of your work- how well you learn to use it is the only importaint factor.
Any of these (or one of many others) would be an excellent tool. I encourage you to pick one and get it- and then learn to use it (only took me 10-12 years, though I expect it can be done quicker ) But, don't loose sleep over picking the right one- in the long run, it's not going to really matter.
PHOTOBUCKET SUCKS
Old 09-06-2005, 09:03 PM
jswillmon's Avatar
jswillmon jswillmon is offline
Send a message via AIM to jswillmon
I love my Iwata Revolution CR. great all around airbrush for all auto modeling situations.
The Name's Jesse!
**Click the pic for my latest build, Daytona Blue 350z**
Old 09-06-2005, 10:00 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
I vote other, I have a Paasche VL that works excellently, and it was quite inexpensive.
Old 09-06-2005, 10:11 PM
ZoomZoomMX-5's Avatar
I can only comment on the airbrushes I have. I have a Rich AB 200 that's a fineline airbrush made by Iwata. It kicks ass. As for the other Iwatas, I only hear good things, but I've never used one.
I have a Badger 150IL, decent airbrush but finnicky to assemble/disassemble and clean.
I have a Paasche VL, big improvement over the Badger 150, easier to keep clean. Requires more air pressure for some reason.
My workhorse is a Badger 175-T Crescendo. It rocks. It comes w/three tips, but I really only need the medium tip for painting bodies. It has much better flow than the 150 or Paasche VL (also has three tips/needles but it just doesn't flow like the Crescendo).
I have an Aztek/Model Master that I like but the needles are prone to early wear, you really can't completely cut off the flow of paint when you're pushing the air trigger. It's good for metalizers.
As someone else said, your technique is more important than the airbrush you get. As long as you get a quality brush, you can do wonders with it. Iwata, Paasche, Badger all are good choices. Just get one and start painting. I know more people who live in fear of an airbrush-they have one and it gathers dust...
My Fotki Album
Old 09-06-2005, 10:59 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Ican't really tell you what airbrush you should get because i myself am looking for a new one, i currently have an aztek airbrush and i really dislike using, prone to breakage, nozzles and airbrush are a pain to clean in my opinion. Not to jack the thread, but are iwata and badgers easy and quick to clean?
In Progress
Old 09-07-2005, 06:58 AM
mike@af's Avatar
[cough]Wayne[/cough]
-Mike
Old 09-07-2005, 09:19 AM
Yes. While at first, they may be a little tedious because they require disassembly, from what I've seen this becomes very easy and quick with experience. When I first started I would spend more time cleaning than I would airbrushing, but now I clean it so quickly it's worth it to bust out the airbrush to paint just a couple small details.
