Old 09-06-2005, 01:26 PM
Chest Rockwell's Avatar
Chest Rockwell Chest Rockwell is offline
No codes-Engine Turns-No Catch WTF!!??
My bro's STD just died out. Tried to start but engine backfired bad!!!
-spark plugs have oil on them.
-Plug wires look ok.
-Rotor,when checked was smashed to shit and was stuck to distributor!!
-Replaced cap.
-Replaced rotor.Is it ok if it's a little loose?(rotation wise)
-Faced rotor to #1 spark plug.
-Found TDC of #1 piston.
-Timing belt is brand new.
-Faced crank pulley to "UP" position.
-Tried to start.No backfire now,but it does kinda sputter!!??
I have tried to find the answer using the search bar but can't find a good answer HELP PLEASE.
Old 09-06-2005, 01:47 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: No codes-Engine Turns-No Catch WTF!!??
The rotor screw must be tight. Rotor screw falling out is the culprit of many non-running civics.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 09-06-2005, 02:12 PM
It feels like the screw is as tight as it can get.The rotor still feels loose. this sucks. thanks though.
Old 09-06-2005, 02:58 PM
SiZ's Avatar
SiZ SiZ is offline
Coil, and ignitor?!
Old 09-06-2005, 03:25 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Yeah check for spark and fuel. If you are getting both of those check your timing.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 09-06-2005, 03:39 PM
What do the coil and ignitor look like? If I found them at a jukyard Would they be small enough to fit in my pocket?=)
Yeah I'm getting spark and fuel.
Whats the best way to set proper timing?
Thanks for the help.
Old 09-06-2005, 03:53 PM
Re: Re: No codes-Engine Turns-No Catch WTF!!??
If you're getting spark then you don't need a new ignitor... you can move your dizzy until it runs right or get a timing light.
2010 Honda CR-V EX
Old 09-06-2005, 06:11 PM
Thanks I'm gonna go at it tomorrow. I'm gonna start all over.
I'm gonna check:
-Rotor
-spark
-fuel
-wires
-fuses
-timing
How can I check if the distributor is screwed??
Thanks.
Old 09-08-2005, 05:07 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
EFI main relay. its under the dash on the drivers side. right above the hood latch
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 09-08-2005, 05:15 PM
Thanks for the info. I know that you can re-iron them. How do you go about doing that? Do I just iron all the points with just a little bit of metal? It's more than likely not the main relay, but I will go ahead and do that just in case.
Thanks.
Hey where you goin with those two hams!?...Oh wait those are'nt hams you're just a Fat kid are'nt you Fatty?
Old 09-09-2005, 10:51 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
your spark plugs have oil on them? in the cylinders or around the spark plug o rings? have you figured why it has oil on them? low and uneven compression leads to many problems
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 09-09-2005, 04:04 PM
The oil is around spark plug o rings. My bro is'nt too woried about his STD engine.He is gonna swap in a SI from crx. He just want's to get it running. Thanks.
