Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 09-06-2005, 01:14 PM
NKSebring NKSebring is offline
RPM drops to zero while driving
Here are the problems I am facing with......
1. When I drive, the RPM drops to zero (sometime on freeway some time driving through town) from time to time. I usually keep on pushing/pumping the gas pedal it usually comes back up and it runs fine again until next time it happens. Took it to the repairshop but could not find out what's wrong with it. It had lower fuel mileage so changed O2 sensor. Cleaned throttle body, idle air control passages, and decarboned the engine. Added fuel system cleaner. The problem still exists.
2. As other forum users wrote, I have a same problem with starting (cranks but won't start) from time to time. I usually wait 1min to 5 min and it usually restarts again.
3. Now the check engine soon light came on yesterday(I don't know if it's related to the previous 2 problems... The car runs but have high RPM(3000RPM when I only go 30 miles/hour).
Does any body have idea?
Old 09-07-2005, 10:11 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: RPM drops to zero while driving
well, all the symptoms are describing a bad crankshaft position sensor. If it lights up your check engine light, the tachometer works when it wants to and has erratic behavior, all classic signs of a bad crank sensor.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 09-28-2005, 04:39 PM
andrea1982 andrea1982 is offline
i have a 1998 and i replaced the ditributor and the crankshaft position sensor and got a new battery and my car still wont start, and when it was running it had the same as the first problem you had to what do we do?????????????????????????
Old 03-20-2006, 10:27 AM
dkunio dkunio is offline
Had similiar problem and found bad relay. There is a cluster bof 3 on the firewall, drivers side. Just swap locations and see if problem changes. Don't just leave them though if it runs. I bought compatable relay at electronics store but it failed again in 1 year. Automotive replacement was 25 dollars but has run great ever since.
