Old 09-06-2005, 12:40 PM
cbubya87 cbubya87 is offline
Replacing Starter in '97 Grand Caravan
Newby here. Wife's ride won't start. Replaced battery yesterday. "Click". All lights, radio, tones, work, however, it won't even attempt to turn over.
I'm assuming that it's the starter. Agree?
If so, how easy are they to change? Where exactly are they located?
If it's not the starter, any idea what it could be?
Thanks,
Chris
Old 09-06-2005, 06:00 PM
wafrederick wafrederick is offline
Banned
The starter is expensive.You can replace the contacts instead of replacing the starter.First disconnect the negative battery cable.Is a 3.0 or a 3.3?It is real easy to replace and is front of the engine below the exhaust manifold.To replace the contacts,there is a cover plate with three 7mm headed bolts and each side there are two copper bolts with a 12mm and a 14mm sized nuts.I do not know where you can get the contacts and that is what goes bad
Old 09-06-2005, 09:22 PM
vipergg vipergg is offline
Re: Replacing Starter in '97 Grand Caravan
Thanks,
Chris
Try cleaning the starter connections before replacing it . these are subject to corrosion .
Old 09-16-2005, 12:10 AM
needanid needanid is offline
I ended up replacing the starter motor myself. It was about $99 for a rebuilt starter and a core charge of $50 for a total of 150. You get your $50 back after you return your old one.
If it is your starter, I recomend that you do it yourself. Its super easy and it could take anywhere from 10 min to 30min.
