Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 09-06-2005, 12:08 PM
gwm gwm is offline
venture transmission problem
I have a 2000 venture. 175,000 km,s. I've never changed tranny fluid.
Since a week ago, it won't change into 3rd gear. Will fluid and filter replacement correct this?
Old 09-06-2005, 04:35 PM
cdru's Avatar
cdru cdru is offline
Re: venture transmission problem
Remote possibly, but not likely. It really depends on what is not working. If it's a valve that is sticking, it's a possiblity. But if it's a worn valve that's leaking or band or clutch plate that's shot, no amount of fluid, filter, or addatives will bring it back.
Vinyl adds horsepower, right?
Old 09-06-2005, 05:03 PM
gls02 gls02 is offline
You have never changed the fluid or the filter, but have you checked the transmission fluid level? I don't know if changing the fluid/filter will correct your problem, but I once had a transmission that didn't want to shift gears (AMC Pacer) and just replacing the transmission fluid fixed it.
If it isn't throwing out any codes I would give it a try and change the fluid/filter and see what happens.
