Old 09-06-2005, 12:40 PM
pryornfld pryornfld is offline
Air Conditioning..Check Engine
Hello All,
Well it seems that my Check Engine Light has returned, but this time the code shows the A/C as the problem. There is a fuse for the AC Clutch that I was thinking about removing. Since it is getting close to fall, really have no use for the AC. Rather save my money and worry about it in the summer. Can I remove the fuse permanently? Is there another way to disconnect the AC without it sending a code to the Computer?
Thanks
Dion
Old 09-06-2005, 12:49 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: Air Conditioning..Check Engine
Originally Posted by pryornfld
Hello All,
Thanks
Dion
I would keep the AC functioning. The defrost uses the AC to clear your windshild.
However, if you do want to keep the compressor from running remove the plug that engages the clutch. It should be just behind the pully on the compressor.
Dan
Old 09-06-2005, 12:59 PM
Re: Re: Air Conditioning..Check Engine
Will this take care of th check engine light?
Old 09-07-2005, 04:04 PM
fcrew fcrew is offline
What is the code that you are getting from the A/C?
Old 09-08-2005, 11:28 AM
Something like 1452?? Can't really remember as the guy I bought it to is now on vacation and I have to get it re-scanned.
Old 09-08-2005, 05:59 PM
gbic1 gbic1 is offline
If he had the a/c on while testing it will leave a code.
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
Old 09-09-2005, 07:10 AM
The AC wasn't on when he tested the codes! How would or why would the AC cause the engine light to come on??
Old 09-09-2005, 10:01 AM
With out the code I could not tell you. I would need the correct code to give you an idea. I have never seen an a/c system set an engine light code. The only time I saw a problem with the a/c was when a diode went bad and spiked the ecm.
1988 Bronco 351 C6
Old 09-26-2005, 10:05 AM
Re: Re: Re: Air Conditioning..Check Engine
I got the codes read over the weekend and it showed 401/402 EGR Excessive flow/EGR Insufficent flow. My mechanic believes that it may be the EGR Selonid/sensor, and if the EGR ports were bad, then you should get only one code.
Any takes on this??
Old 09-28-2005, 08:08 AM
krewl1 krewl1 is offline
You may have to replace your egr valve or I found out on another one of my cars was that i had excessive carbon buildup so i cleaned it out of the egr valve and also cleaned the throttle body and have had no problems since.
Old 09-28-2005, 11:25 AM
DRW1000 DRW1000 is offline
I would check the DPFE itself. The DPFE "measures" the EGR flow and reports to the PCM.
Since you are getting conflicting errors I would suspect this item first.
There is a test procedure buried in this forum somewhere.
The DPFEs are common failure items
