Install Tachometer Issue
First off, Before getting a bunch of "that's stupid and pointless" replies, it's for a customer. I KNOW it's stupid and pointless to have a monster tach, but it puts food on my table. With that in mind....
I need freakin help!! I installed a customer's monster tach and thought I found the wire on the coil under the distributor, but that wasn't it. It's doing the same thing installing a tach on a ford does... you rev high, and the monster tach doesn't go any higher than 2ish. I called dodge for some help, and they didn't even know. Said they'd lost their books. So I've got no clue what wire to hit... Can I get a helping hand from ANYBODY that might know or has a Chilton's style manual laying around. I made the poor customer come back because there was just no way to find out!! I HATE installing these things sometimes...
Hung by a halo or stabbed by horns, sad to say; they're both the same |
Re: Install Tachometer Issue
Anyways, to answer your question, did you splice into the wire in the PTU that is labeled "TACHO"? if the picture doesnt show up, go here http://www.stealth316.com/2-pwrtransunit.htm but, IMO, it would be easier just to tap into the ECU RPM wire. This page has the diagrams of the ECU pin numbers, and the RPM pin number is shown (dependent on ECU) towards the bottom of the page. http://www.stealth316.com/2-ecu94.htm
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Why is it stupid????
what kind of tack is it? I have one but I dont know if essentially the wireing is the same. Edit: its the solid white wire btw. it plugs into the engine, you can see the harness right below the valve cover, passenger side towards the front. and dont make fun of people just cause you dont like the stuff they install. I for example got one cause the helmet I have is very restrictive and I have to tilt my head down to look at the dash and often lost sight of the course whenever I autocrossed. now I dont have to take my eyes off the course.
![]() 06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake, Ported Intake Manifold, Ported Throttle body, MAF screen delete. Tunned by Jeremy Formato. 381whp, 376wtq. 07 Ion Redline: Bone stock w/ factory Competition package. In response to a race my wife had while pregnant with our baby: Quote:
I don't care what people get or why. The only reason I said that is when I asked the question once all I got were a crapload of replies saying how stupid having a monster tach was and nothing helpful. I was getting it out of the way.
thanks a ton for the advice!! That worked. You just went up a point in my book hotshot!!
Re: Re: Install Tachometer Issue
glad i could help, i've installed enough e-manage's and other rpm based electronics to know where the rpm lines are.
