Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 09-06-2005, 08:44 AM   #1
wackypappy
88 4.0 vacuum picture
need a real good view of the vacuum hookups on a 88 4.0 engine...installed engine but now i cant remember where all the lines go....thanks again fur all the help i have got here.
wackypappy is offline   Reply With Quote
Old 09-06-2005, 09:19 AM   #2
runuover
Re: 88 4.0 vacuum picture
look on some of the forums they have pics on the vac lines. i dont know where thrir at but i seen it there the other day.
runuover is offline   Reply With Quote
Old 09-06-2005, 09:23 AM   #3
wackypappy
Re: Re: 88 4.0 vacuum picture
ok me take a look...thanks.
Old 09-06-2005, 10:52 AM   #4
89ltd
I know where everything goes, let me know what info you need.
89ltd is offline   Reply With Quote
Old 09-06-2005, 11:54 AM   #5
wackypappy
need where lines go on carb side of the engine..thanks much.
Old 09-06-2005, 09:42 PM   #6
89ltd
do you mean throttle body? you have mfi ? I have an 89, think most should be the same, unless yours is california.
Old 09-06-2005, 11:21 PM   #7
wackypappy
sorry i guess i didnt make it clear enough on what i need...vacuum lines...all lines....i just installed engine and not sure if i have the lines hooked up right...i had to plug up a few of them up...engine runs fine even with some pluged......i hope you can understand what i need..
thanks much
Old 09-07-2005, 04:17 PM   #8
89ltd
i would think that the fuel regulator has vacum or it wouldn't run, same with the map sensor(vacum hose from thottle body to map sensor). You need to have a vacum source to the egr valve solanoid and then to the egr valve.
Old 09-07-2005, 04:34 PM   #9
89ltd
also a vacum source to the air box cover where the temp sensor is , to one side, then from to the other side to vacum door on the front of the air box.
Old 09-07-2005, 06:03 PM   #10
wackypappy
thanks much.....would you have a drawning showing the above and egr....i have a broken line and now i dont know what it hooked to.
thanks again
Old 09-08-2005, 02:20 PM   #11
Saudade
Saudade's Avatar
https://www.autozone.com/servlet/UiB...3d8015252c.jsp
Then click the link for your engine.
Saudade is offline   Reply With Quote
Old 09-08-2005, 03:28 PM   #12
wackypappy
thanks much...that did help me......
