Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 09-06-2005, 06:57 AM
fallon19 fallon19 is offline
Radio Problem
Hi
I have a 98-99 Passat with no AM signal at all and a pretty weak FM signal that can drop out at any given time. When I turn on the interior light or use my indicator or even turn on the heated rear window, you can hear the "pop" of the change in the electrics. I have done some testing after reading stuff on here and this is what i got:
BNO T:4
FERN AUS
GALA AUS
VERS 30581003
Any ideas what this means and how I go about fixing it would really be a help to me
Thanks in advance
Fallon
Old 09-07-2005, 11:11 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
one of your antenne cables is shorted. Most likely the easiest ( antenne mast and base). But also the long long cable that goes from mast to shifter area goes bad also. Thats normally on wagons.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 09-13-2005, 12:42 PM
Re: Radio Problem
Thanks for the advice
Should I take it to a pro or is it something that could be solved without much trouble?
I looked inside the headlining today and saw the aerial lead and securing nut, but haven't done anything as of yet, what should I do next?
Old 09-13-2005, 10:07 PM
VDUBMAN
The arial is a 22mm. I would suggest buying a 22mm stubby (6inch) wrench at a cheap tool store for 10.00 and replacing the antenne yourself. ( dealer would problably charge 100.00 fo replace it)
