hi i jus registered because im gonna get a vr-4 in bout two weeks, 1994 white vr4 with 99 front end conversion it has 3SX Performance Pre-Cat High-Flow Downpipe, Boral Cat-Back Exhaust, Random Technologies Ultra High-Flow Cat ,K&N Filter Intake Performance Kit , Supra High-Flow Fuel Pump, RC Balanced 360cc Injectors, High-Flow Fuel Rail Adaptor,....i jus listed it coz of the increase in power, but yeah my question is whats the lowest psi i can boost that wont cause the engine to run like a pos or anything, i want to know so when we test drive it my parents wont think its too strong or anything, and im thinkin to run the lowest psi i can for fuel economy, n whats the most i can run it? any help is great,once again im new to forums n all so dont make fun of me plz
Re: how low can i boost
Well at this point with those mods, your only options are stock boost at 12psi. You don't have a boost controller or a decent boost gauge, so you can't turn it up or down. To turn it up you would require the boost controller, boost gauge (not the stock one), larger injectors (360ccs are stock size), and an air/fuel controller in addition to the mods you have. Once you have those mods, you could start turning up it to maybe 14 or 15. As well you could turn it down to wastegate pressure (6 or 7? psi)
If you want your parents to think it isn't that fast, then just shift low and don't race it around. But realistically it is a fast car with those mods, you are looking at somewhere in the 330-350hp..which is sure enough to hurt yourself with...so drive safe. I really don't recommend a vr4 as a first car, and I know many on here feel the same way.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Yea it is a fast car with those mods but hes right if you just shift at low rpms and don't take it over 4 grand or so then it really wont boost that hard. Since you have the stock boost solenoid which is about 9 to 11 psi thats where you will be boosting but after 4500 rpm the stock solenoid drops it down to wastegate pressure. Its fast but just make sure you don't get into boost.
92 Stealth R/T TT CURRENT MODS: K&N FIPK Spec Stage 3 Clutch 6 Puck HKS Turbo Timer Type-1 3 Inch Polished Y-Pipe Greddy Profec B Spec II @ 12.0psi Greddy Type S BOV Greddy Catch Can Borla Exhaust 3 Inch SS Down Pipe with Race Pipe 3SX Crank Pulley Accel 8.0mm Wires Gen 3 Lifters High Flow 290lph Fuel Pump (Supra Pump) Plugs Gapped at .030 Iridium IK20's 550cc RC Engineering Apexi S-AFC II (WILL BE REMOVED NOT YET) 2 G-16 Turbos AEM EMS FUTURE MODS: Custom FMIC |
