| Off-Topic Talk about anything other than cars. |
i searched through the threads and couldnt find anything on this but here goes
i have a 95 eclipse with a garret tdo5 turbo and a greddy fmic and there bov and ic piping, all thats messing it up is the transmision "automatic" i could leave it like that but lets face it manual is just way better, just out of curiosity is it posible to just convert to a manual? and if so is there any modification to the body or frame,or is it just a matter of swaping parts out and changing the shifter housing and things like that, this seems to be the place to come for info like this, so let me know if it can be done... thanks for your time. |
Re: swap automatic to manual transmision possible???
with money anythings possible, sure but you have to do modifications, you need a clutch system, cut holes in the firewall where cables would go through, the petal ect.... i converted one car but not a talon...or 'eclipse
The manual transmission from any 2g DSM will bolt to the motor just the same.
If you know your way around a DSM it would be an easy and straightforward swap, the most frustrating part is swapping the pedal assembly and running the hydraulic lines for the clutch, and the shifter cables. Minimal drilling is involved, but generally idiocy will lead to disaster, or, more likely an incomplete project. |
Try searching again, this subject has been brought up many many times in the past. Using the keyword "swap" returned lots of results for me.
1993 Eagle Talon ES (4g63NA) 14.6 @ 98 mph (110 octane race fuel) -5 Speed Transmission (From a 4g67) -Stage 2 Crane cams -Ported and polished head -Aggresive valve springs -2.5" Custom made exhaust piping -Custom header -Gutted catalytic converter -Bored 0.5mm -Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC) -2g valve lifters (Lifter noise returned, now it a true DSM) -K&N w/modified air canister |
Possible....yes
Easy.....NO Costly....YES Frustrating.....YES Worth the Money.....NO
'92 3000gt SL Zoom Stage 1 Clutch Quote:
why not find a similar year car with a blown engine. Or buy another car; swap parts; sell the auto. I shouldn't be talking since I'm putting a turbo on a non-turbo. But the price difference between a stick and auto shouldn't be that much.
99' eclipse GS 420A !!!TURBO!!! Hahn kit installed. still on stock everything else, including exhaust. I know it's taking FOREVER to finish the write up but the bands been taking off lately killing my free time. I've got some pictures posted though if you want to check it out. www.angelfire.com/indie/kbracing ![]()
