Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 09-05-2005, 09:31 PM
redron redron is offline
1998 jimmy stalls evry day when first started
My 1998 Jimmy spits and sputters first thing every morning and sometimes stalls out, right after starting I try to give it gas but it won't take it, the gas pedal goes down and I don't go anywhere This will also happen sometimes after the cars has been off for about 30 minutes. Other than that the car runs great, smooth and usually starts right up and goes. I've had a complete tune up with new fuel filter and all the other stuff. I'm tired of garages not being able to fix this but yet always find a way to charge me for something !!! HELP Again this happens after the truck hasn't been running for atleast 30 minutes and then once I finally get started and moving she runs perfect
Old 09-05-2005, 11:51 PM
drdd's Avatar
drdd drdd is offline
Re: 1998 jimmy stalls evry day when first started
what did your tune up include ?
Old 09-06-2005, 06:26 AM
Re: Re: 1998 jimmy stalls evry day when first started
New spark plugs -spark plug wires - fuel filter- air filter- distributer cap- rotor plus complete check of the fuel system and ignition system. This was the first repair a shop said needed to be done to fix the problem, needless to say they were WRONG
Old 09-06-2005, 08:03 AM
drdd's Avatar
Re: Re: Re: 1998 jimmy stalls evry day when first started
I would start with two cheap things - clean the throttle body and clean the IAC. If that doesn't solve it, it most likely needed done anyways and you've only spent a little time and about $3
Old 09-09-2005, 10:13 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Check fuel pressure.
Also check battery voltage at idle and while running.
1995 Factory Blazer Service Manual for sale, PM if interested.
